Machine Vision
measure distance between several points
Hi
I am trying to measure distance between two edges. The problem is that the edges deforms. (Se attatched drawing-Sample)
Is there a VI that draws several points along an edge (like the clamp VI) and measure the disatance between two and two points?
Regards
Anders
(3,306 Views)
If you look at the details of the clamp routine, it uses the rake to locate each of the points.  You could simply use the rake routine to get the edge points and process them yourself.  You should be able to easily extract the edges on each line and determine a measurement for each line.
Bruce
Bruce Ammons
Ammons Engineering
(3,277 Views)
Hi
I dug into the clamp VI and found the output "All Edges" which gave me all of the points and coordiantes that I wanted.
Regards
Anders
(3,273 Views)
