Machine Vision
know about camera on status
hi,
     i want know about camera on status while run time un plug the camera(usb cable).i attached vi and camera setting and model information.
a).i am using camera trigger mode
Message 1 of 12
(4,543 Views)
if I understand well
you want to know when and what kind of cameras are plug to your system yes?
use imaqdx enumerate cameras vi for this reason
Message 2 of 12
(4,521 Views)
yes, i want know about when camera cable is unpluged.but my while loop is runiing continuously it give time out error.
Message 3 of 12
(4,515 Views)
use this vi it will help you
Message 4 of 12
(4,505 Views)
this is not working because camera is trigger mode so it give if the camera connected time also time out error.so it toggling plug and unplug.
Message 5 of 12
(4,501 Views)
I add loop to your vi that check if your camera is conect or not check this vi may be it could help
Message 6 of 12
(4,498 Views)
if camera is conneted or not connected it always give is same setting(array zero index data only).
Message 7 of 12
(4,494 Views)
two thing you should regard it
1 this method need time and is not immediate
at least 1 or couple second based on your camera time out is need to this method know if camera is unplug
2 if this vi show always unplug it seem you did not inter camera file name completely
(maybe extra inter at the end )
but you can fix it by changing compare part
for example if you have just one camera you can check array size and if this size become zero so camera is unplug
Message 8 of 12
(4,483 Views)
yes i accepts that but defaulty came same setting when connect or not conneted both the condition.
Message 9 of 12
(4,482 Views)
sorry I do not get your last post means
Message 10 of 12
(4,476 Views)
