Hi all,
I'm using the IMAQ particle filter 2 in LV 8.5 and I don't really understand how the keep/remove logic works.
If the input array "
selection values" has only one element, e.g. centre of mass X, particle that are out of the specified range will be removed if "
range" is false.
This is what I expect.
selection values" has more than one element, e.g. centre of mass X and center of mass Y, then I expect to have in the end only particle that are in both ranges and this is not what happens.
When the input array "
selection values" has more than one element, the filters are not applied sequentially and I have to do it like on the screen-shot below :
The detailed help doesn't tell what happens when the are more than one element in the input array "
selection values". So can anyone tell me how it works in such a case ?
Thanks in advance
Message Edited by TiTou on
02-04-2008 10:02 AM
Epictetus
Antoine Chalons
