Machine Vision
imgPlotDC
hello,
i try to use imgPlotDC instead of imgPlot in the llring-example (../NationalInstruments/NI-IMAQ/Samples/MSVC/RING/).
but with the code below no camera image is shown in the main window...does anybody have an idea what's wrong?
thank you very much and best regards,
malte
// Get the device context associated with this window handle
hDC = GetDC((HWND)ImaqSmplHwnd);
// Create a compatible device context for the drawing off-screen
hMemDC = CreateCompatibleDC(hDC);
// Create and select a bitmap in our device context to receive the image
hBitmap = CreateCompatibleBitmap(hDC, AcqWinWidth, AcqWinHeight);
hOldGdiObj = SelectObject(hMemDC, hBitmap);
// Display the acquired image in the bitmap
imgPlotDC ((GUIHNDL)hMemDC, (void *)CopyBuffer, 0, 0, AcqWinWidth, AcqWinHeight,
0, 0, plotFlag);
(3,861 Views)
Have you tried to use the BitBlt() function after the imgplotdc?
Have a look on the attached code...
If this doesn't work with the BitBlt() function, let me know which version of IMAQ you are using...
regards
Thomas Sandrisser
(3,847 Views)
that was the problem...thank you Thomas!
best regards,
malte
(3,835 Views)
Hi Thomas,
Thanks for sharing your c-File !
It saved me a lot of time (5)!
Greetings from the
Lake of Constance,Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,527 Views)
