Machine Vision
imgPlotDC function
Has anyone used the imgPlotDC() function to plot a captured bitmap onto a
memory DC? When I use that function to plot to a window DC it works just
fine, but when I try to use a memory DC instead nothing happens. The
function returns success, but no bitmap is plotted.
What I am trying to do is to plot the bitmap onto a memory DC and then
display it as either grayscale or false color by changing the memory DC's
palette.
Also what is the layout of the pixel bits in a captured bitmap? Is it the
same as a Windows bitmap, or some different format?
If anyone has the answers to these questions, please post or send me an
email.
Richard
(3,948 Views)
I have used this routine. You have to call BitBlt() after imgPlotDC().
I attach code samples.
The captured data passed to imgPlotDC() is just an array of unsigned char and not a Windows bitmap.
(3,948 Views)
