Machine Vision
imaqRotate2 fails with 1600x1200 images again
The last solution is not working. It only takes more cycles to fail.
(3,017 Views)
Strange.
If you need to have only 90 / 180 / 270 degrees rotation, then I will suggest to stay away from imaqRotate and develop your own rotate function. Its only few lines c code.
Andrey.
(3,013 Views)
Hi Garcia,
Please try not to create multiple threads with the same question.  Duplicate Post.
Adam H
(2,991 Views)
