Machine Vision
imaqLearnCalibrationPoints
Hi. I want calibration my image using a pattern of 4 points. I have the pixel value and the realworld value of each pixel, but I don't understand and I don't find exemples to pass this values to the imaqLearnCalibrationPoints function.
ThankYou very much for your help!
(3,784 Views)
Gualty,
have a look to the following path on your PC
C:\Programme\National Instruments\Vision\Examples
You will find several examples for Vision
regards,
ThSa
(3,762 Views)
Hello ThSa,
       I have seen the examples and the documentation but I am a beginner of CVI (and C also) and I don't  find how pass the pixelvalue and realworldvalue to the imaqLearnCalibrationPoints.
The attached file is a base structure af my application. I want acquire an image and then calibrate it according this values:
pixel                         realworld
100.0,100.0             0.0,0.0
300.0,100.0             50.0,0.0
100.0,300.0             0.0,50.0
300.0,300.0            50.0,50.0
Can You send me a correct version af my file with this values passed to the function ?
(3,750 Views)
Is the answer to your questions posted over here?
http://forums.ni.com/ni/board/message?board.id=200&message.id=8917
Regards
AlessioD
(3,743 Views)
Hey AlessioD,
      I have checked the exemple, but I have an "Too many initializers" error an the cursor is in the point indicated with a "e":
PointFloat pixelCoords[] = {{100.0, 100,0},  "e"   {300.0, 100.0}, {100.0, 300.0}, {300.0, 300.0}};
Do You know why? ThankYou for your help!
(3,737 Views)
