Machine Vision
imaqFlatFieldCorrection
Dear all,
I am using imaqFlatFieldCorrection() with brightFieldImage for my machine vision application in order to remove vignetting effect as well as dust on the lens and other background imperfections from the image before performing different measurements on my object.
The algorithm works very well but I need to better understand what is behind since I need to be 100% of how this may affect the measurement I do with the flat-field-corrected image.
The information I have found online is very high level (even the "in depth discussion") so I would like to know if someone from NI or other users would have a more exhaustive documentation about this function.
Thanks in advance,
(2,442 Views)
Hi Lloren,
You can find detailed help for the LabVIEW Machine Vision modules in the concept help guide, which has a specific menu for Flat Field Correction.
Other Links that may be of use:
Hope this helps,
David Guest
Technical Support Engineer
Platforms & Systems
(2,364 Views)
