Hi,,
I have a RTOS on a PXI system. I want to acquire pictures with a
IEEE1394 camera. Everything works fine. I can also save them on the
hard disk of the remote system (real time system), but I want to save
them immediately on my host system. I didn't find any solution. I tried
the example "Save image on remote system .vi", buzt it didn't work If
I use the wrong port, there is the error 64, if I use the correct
port, the program stops and no error is given out, but also no data is
stored on the host system. Where can be the problem?
in advance
Tim
