I'm not sure what you are trying to do with it, but I can tell you how to do it.
If you are using IMAQ Vision, you need to use IMAQ Image to Array to convert the image to a 2D array. Once you have a 2D array, you can use array to spreadsheet string and write string to file to save it as an ascii file.
If you aren't using IMAQ Vision, you can use the picture controls to load the image. Unflatten the output of the load image vi to get a 2D matrix, and continue as before.
Bruce
Bruce Ammons
Ammons Engineering
