Machine Vision
.iak files - how to disable?
I have a question about *.iak file. The problem is following. I have a project. Within project I have libraries. Every time when new library is created I must add library to source code control.
So, right mouse click -> Add to Source Control... Now in the list I have two files: My library.lvlib and My Project.iak file (which is not exists). Every time I should deselect this file, otherwise SCC reported, that this file cannot be found. Exactly the same happened with check in/check out.
How can I disable this in general?
This *.iak file seems to be from FieldPoint or so, but in the project only standard components+Vision are used. Nothing FieldPoint-related.
Which VIs or properties are responsible for this?
thank you in advance,
Andrey.
(4,022 Views)
Hello Andrey,
This is very interesting issue.
Could you please explain to me what kind of SCC application are you using?
AmirG
(3,963 Views)
Microsoft Visual Source Safe 6.0 (Build 8163) is used.
Interesting that new clear project is free from this issue. But now I have a project which included 500+ SubVis, and this happened. Seems to be some VIs caused this problem, but I don't know which one.
Andrey.
(3,961 Views)
I have the same issue ...
All the time I need to Check out a .lvlib or the .lvproj a .iak apper in the list of file to check out and when I click ok i got this error
"Error -2905 occurred at SCC_Item_OnCommand.vi.ProxyCaller  An error occurred trying to check out the specified file(s)."
If i unselect the .iak file in the list i got the same error.
The source control in LabVIEW is unusable when this appen .
I use LabVIEW 8.2.1 and Source Safe 8.0.50827
LabVIEW ChampionArchitect
(3,836 Views)
I found a work around. Create a blank .iak file and add it to your project and to source safe.
Dany
(3,834 Views)
