Machine Vision
how to send variable from vision builer to robot?
hi all,
i have a project with vision builder that generate variable of position.these varible i want to send it to a robot.it  is possible to send it directly from vision builder to the robot or i must to send varible ti labview firstly then to robot?
best regars
(4,588 Views)
Yes, you can send it directly to the robot using TCP/IP protocol:
Vision Builder can be a server or a client. You can send data in string format or in raw format.
Kind regards,
Nikita.
Did you know LabVIEW can control industrial robot arms? - www.digimetrix.com
(4,578 Views)
