Machine Vision
how to create median and spatial filter for continuous acquistion
Hi all,
I am trying to do some image processing , I want to make an application which will do median filtering and spatial filtering with continous acquisition of images from a gige vision camera. I tried to use nth order vi but I couldnt understand whats the filter x and y should be . images from camera are Mono 8 with height and widht set to 1000. how should i configure the median and spatial filter to do this processing continously with acquisation. I want to have atleast 5-6 frame persec for my filter. attached is my try with median filter  if I change my filter size (x-y) to more then 10 , my labview crashes.
Please tell me how can I configure the median and spatial filter for this image processing application.
(5,727 Views)
can you post the code for previous version (2013 for example)?
I am guessing you did not increase the border size of the image? This is needed to establish "room" for the convolution kernel...
For example, a 5x5 convolution kernel, requires a border size of 2. For a 9x9 you need a border size of 4. I think the default border value when you create an image is 3, so 7x7 kernel is possible.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,706 Views)
K
Hi Klemen,
Thank you , I saved it for 2013 version. Please take a look
(5,696 Views)
to apply a median filter of n-th order, use the equation:
n = (kernel_size^2-1)/2
So, if your convolution kernel is 9x9 in size, the order should be: n = (81-1)/2 = 40. Also, do not forget to create the proper border size, in the case of 9x9, the border size should be 4.
Also, have you seen IMAQ convolute? The median filter is a non-linear filter, whereas the convolution is a weighted sum of pixels (linear filter).
The median filter is often used to reduce the speckle noise in the images.
What is your goal?
K
(5,678 Views)
What is your goal?
K
Hi Klemen,
thank you, the final goal is to do the median/spatial filtering during the acquisition (with 5+ frames per sec). I have Gige vision camera which will do the continuous acquisition and the user will see the unprocessed image and a processed image( filtered, denoised image) without much lag.
basic idea is to present user a continous processed images( noise removed).
ankit
(5,671 Views)
