Machine Vision
how to acces the digital IO of compact vision
It seems to me that the FPGA Module 1.0 software is necessary to access the digital IO of the compact vision module. Is this true?
If not, can someone tell me how to use the dig. IO?
Kind regards,
Jonas Van Otterdijk
(3,270 Views)
Take a look at the User Manual for the 1454:
http://digital.ni.com/manuals.nsf/webAdvsearch/AF89EC93DFD41EA386256D3B006B819E?OpenDocument&vid=niwc&node=132100_US
Chapter 4 has information on how to use the digital IO and where to find examples to use it.
You do need FPGA to access the FPGA personality on the CVS, as you will see in the example program. Everything you need should come with the CVS though.
Hope this helps-
Julie
(3,270 Views)
