Machine Vision
finding beginning and ending coordinates of an edge
Hello Guys,
I am trying to find two points:
1. top left
2. bottom left
on one of the pictures, i colored the section of interest to see if that would yield better results on the vision assistant, but i haven't been successful in finding the edge.
in my application, i need to come down and shave a portion of the top (shiny) part starting from the edge.
2021-05-07 11-02-06 APA CNC Capture.png2021-05-07 10-56-40 APA CNC Capture.png
any help here will be appreciated.
Message 1 of 32
(6,311 Views)
here are two more pictures where i moved the fixture slighly to the left so that the shiny cover is not present, 2021-05-07 11-29-37 APA CNC Capture.png2021-05-07 11-25-55 APA CNC Capture.png
Message 2 of 32
(6,304 Views)
maybe this is not the way
Message 3 of 32
(5,913 Views)
Message 4 of 32
(5,900 Views)
Is it practical to always color the surface of the part you want to trim?  That would open up several simple techniques.
Message 5 of 32
(5,886 Views)
thanks for the tip
Message 6 of 32
(5,837 Views)
If you can mark the area of interest, you can filter on the color of the marking, or, better yet, use a fluorescent marking system, and illuminate with UV light.. Only the mark will show up and likely have crisp edges.  Blob tools can be used to locate upper left and lower right corner.
Message 7 of 32
(5,822 Views)
I will look into that as soon as i get a breather.
Message 8 of 32
(5,753 Views)
Message 9 of 32
(5,657 Views)
Message 10 of 32
(5,637 Views)
