Machine Vision
fastcamera13 camera file
Hi.  I have a Fastcamera13 high speed camera, and I would like to use it with the NI PCIe-1429 Image Acquisition card.  Has anyone here successfully been able to do this? Is there a camera file lieing around for the Fastcamera13? Thanks!
Oliver
(3,151 Views)
Oliver,
We do have customers using both the FV13 and FV40 cameras with the PCIe-1429, and the applications I'm aware are using the cameras in 10 tap, 8 bit mode.  If you don't see a camera file on our camera advisor at ni.com/cameras, then we probably don't have one.  You can use the Basler A504k camera file with the FV13 camera in 10 tap, 8 bit mode.  Set the 'Exsync' attribute off.  If you want to use the camera in other modes, then download the NI Camera File generator and create your own camera file.
ftp://ftp.ni.com/support/imaq/pc/ni-imaq/cfgenerator/
Brent
(3,141 Views)
