Machine Vision
eyeball and eyeblink controlled robot with obstacle avoidance system for disabled
i am working on this project bt i am unable to detect eye ball
Message 1 of 14
(6,682 Views)
Accepted by topic author bikas
some pointers:
https://decibel.ni.com/content/blogs/kl3m3n/2013/10/08/real-time-face-and-eye-detection-in-labview-u...
http://forums.ni.com/t5/Machine-Vision/eye-controlled-wheelchair/td-p/2651903
Hope you find it useful.
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 2 of 14
(6,676 Views)
actually i have seen that before...although i followed ur idea i am getting the same error opencv_core246 missing.
Message 3 of 14
(6,666 Views)
Hello.
Do you have OpenCV installed? You need to install OpenCV 2.4.6:
http://opencv.org/
Then add:
C:\Program Files (x86)\OpenCV 2.4.6\opencv\build\x86\vc10\bin
to environment variables ("path" under "system variables").
K
Message 4 of 14
(6,663 Views)
hello kelmen i have already installed opencv 2.4.6 bt unable solve the problem and getting the same error
Message 5 of 14
(6,662 Views)
did you add the OpenCV path to environment variables?
K
Message 6 of 14
(6,659 Views)
will u tell me how can i add opencv path to environment variables?
Message 7 of 14
(6,645 Views)
you should read the posts more thoroughly! 🙂
Please check three posts back! For instructions on how to add path to system variables: Instructions .
K
Message 8 of 14
(6,641 Views)
now i have added the opencv to environmental variables under system variables bt still i am getting the error
Message 9 of 14
(6,635 Views)
that is strange. Are you sure you are meeting all of the below requirements:
1. OpenCV 2.4.6
2. Visual Studio 2010x86 (I think Microsoft Visual C++ 2010 Redistributable Package x86 should do it, but I am not entirely sure, since I have not tested this)
3. Modified environment variables (add path C:\Program Files (x86)\OpenCV 2.4.6\opencv\build\x86\vc10\bin).
Also check the comments here: https://decibel.ni.com/content/blogs/kl3m3n/2013/10/08/real-time-face-and-eye-detection-in-labview-u...
I have just tested the SW package and it works without any errors, so the problem must be on your side.
Hope you get it working.
K
Message 10 of 14
(6,629 Views)
