Machine Vision
display image cwimaqviewer in c#?
i want to display a variable of the type bitmap in the cwimaqviewer from the vision library, how can this be done?
a workaround is to copy the image variable into the clipboard but this is not really proffessional
can anybode help me?
(3,895 Views)
Hi there,
One possibility is to save your image in the hard disc.
Use  cwimaqvision1.ReadImage(cwimaqviewer1.Image, yourPath, cwimaqviewer1.Palette) to load the image from the hard disc.
hope this could help.
(3,891 Views)
hi, thanks for the answer but is there really no other opinion to e.g convert a bmp into a cwimaq image file? that it is possible to attach the image?
(3,887 Views)
hi,
You can also create a new CWIMAQImage. Use ReadImage function to load your image to CWIMAQImage.   Then you can attach the image whenever you want. Pay attention that, the type of CWIMAQImage is U8 by default when a new one is created.
Is this what u want?
(3,885 Views)
how can i convert a bmp into a cwimaqimage?
(3,882 Views)
Accepted by topic author kumi
hi,
Here is a example.
NationalInstruments.CWIMAQControls.CWIMAQImage IMAG_Source = new NationalInstruments.CWIMAQControls.CWIMAQImage();
IMAG_Source.Type = NationalInstruments.CWIMAQControls.CWIMAQImageTypes.cwimaqImageTypeRGB32; //depends on the source image.
CWIMAQVision1.ReadImage(IMAG_Source, "@c:\image.bmp", CWIMAQViewer1.Palette);
IMAG_Source is what you want.
(3,880 Views)
