Machine Vision
display cursor automatically
Hello
I have some couples of coordinate for a point and I have already displayed my three points in red with IMAQ Overlay function
Now I want to display a cursor on each point instead of a point.
Is there a function for that?
Thanks for your help
Luckyloic
(3,733 Views)
Hi!
What do you want your cursor to look like?  Usually, you need to use a little math with the existing overlay functions to draw out your desired shape.  For example, the code below uses the IMAQ Overlay Line function twice to draw a 5 pixel by 5 pixel cross.
20785i80987E1028127488
Let me know if you have questions about applying this technique to your desired shape.
Alex Person
Alex Person
NI-RIO Product Support Engineer
(3,730 Views)
Hi
I would like a crossfor my cursor so the VI you showed me is perfect
But is the while loop compulsory to do that? I try to avoid loop when it is possible, but let me know.
(3,727 Views)
I just used the while loop to allow the user to continually update the position of the point.  You won't need to use it in your application if you don't need a loop.
Alex Person
(3,709 Views)
