Machine Vision
detecting lines in RGB 32 Image
Hi I am trying to detect lines in an RGB 32 schematic line drawing. I try detect lines,vi, but it does not find the endpoints of the lines when they are near "busy or conngested" areas of the schematic.  When I go to Vision Asst, it gives me an error saying that the detect lines.vi (P/O detect shapes) is only for use in a binary image.  Should I convert the image to a binary one, I may lose image quality...and I do not know how to convert the RGB 32 to a binary one...What should I do
(3,222 Views)
Normally the occurs because detect shapes function only works in the binary image.
No, you dont lose much of image information. It's basically how best you choose your segmentation (binary conversion) method.
see the attached example for simple image conversion in vision asst.
Silver_Shaper | CLD
(3,206 Views)
