Machine Vision
curve detection
Hi evryone
Can some tell me or its possible to detect and calc a curve and display a result
like this curve has a radius     22  meters
so i want to know or its possible to do this with vision
Message 1 of 8
(4,518 Views)
sorry here the original file
Message 2 of 8
(4,503 Views)
cees10,
You can find and measure curves in an image using the IMAQ Find Circular Edge 2 VI.  This VI allows you to select an area of interest and finds a circular edge and returns information about that edge including the radius in pixels.  It is possible to calibrate your system to convert the pixel value into a real life measurement.  Belos is a link the the help file for IMAQ Find Circular Edge 2 VI.  It contains more information about how it works.
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_find_circular_edge_2/
Sam K
www.ni.com/support
Message 3 of 8
(4,465 Views)
i trid and tried   did not succeed
meaby i took the wrong module  is it possble to point out in a  pic   with item should pick   (since there is no circle)  only a curve
Message 4 of 8
(4,454 Views)
cees10,
The IMAQ Fit Circle 2 VI may be of use to you.  This VI takes a set of 3 or more points and tries to fit a circle to them.  It returns the center, radius, area and perimeter.
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_fit_circle_2/
Sam K
www.ni.com/support
Message 5 of 8
(4,449 Views)
sammy thanks for the answer
but did you tried this with my example
and did you succeed with it?
if so can you sent me a screendump of it.
regards
cees
Message 6 of 8
(4,443 Views)
Cees10,
I did not try this with your specific image.  You should be able to get this to work with your image, however it would help if there was more curvature to the image.  You may want to try to get a more 'zoomed out' image if possible.
Sam K
www.ni.com/support
Message 7 of 8
(4,419 Views)
well thats one of my problems
The first image it totaly zoomed out
the last one is a zoomed in
and the curve is 22 meter    /radius
i can not get it to work   because   it seems that vison sees it like a straight line     (but its not)
Message 8 of 8
(4,414 Views)
