Machine Vision
coordinate transform--robot
hello master:
  as i knew, the unit of coordinates of center return by "Pattern match" is "pixcel" in image. but actually we may send coordinate with "mm" or "cm" unit  to robot in application. my question is how to transorm the coordinate from "pixcel" to "mm" or "cm".  is there any master could give me information or example on how to do  it?
  thank you very much in advance.
thanks and best regards
viming.chen
Message 1 of 34
(7,095 Views)
any help?
Message 2 of 34
(7,073 Views)
You can directly map the pixels to your measurement cordinates. Can you physically measure how much mm your object is and see the corresponding pixels in the image.
Message 3 of 34
(7,033 Views)
you have to calibrate your image first
Message 4 of 34
(6,940 Views)
sir, how to do it? now i have a application to do like this:
a PCB on the position of production line, use Camera to postion it and tell the robot coordinate to fetch it out?  i know how to pattern match, but i don't know how to translate the coordinate that we got from pattern match to the coordinate which Robot use.
thanks.
Message 5 of 34
(6,465 Views)
how to calibrate the image first ,sir?
Message 6 of 34
(6,464 Views)
hello sir:
  thanks for your reply. i had read some information about the calibration. but i don't know how to calibrate step by step with "NI Calibration training interface" . would you like to give me a sample or example on this topic? thanks you very much~
Message 8 of 34
(6,452 Views)
there is many example for this request inside NI example
check these bellow
Message 9 of 34
(6,449 Views)
Message 10 of 34
(6,448 Views)
