Machine Vision
convert text from an image to speech
Hello...I have successfully read characters from an image using OCR but I am unable to built a vi which can convert those characters of an image  into sound
I have attached the image
(5,835 Views)
Hi Dilpreet
If you are on a Windows machine there is a .NET assembly that will convert text to speech. It is System.Speech
Have a look at the example below
Mike
(5,817 Views)
Thanks for replying
but I dont find any .NET assembly in my PC
(5,795 Views)
What happens when you drop down a .NET constructor on the LabVIEW block diagram, It should open a list of assemblies for you to work with.
Mike
(5,788 Views)
sir, i have a dought regarding image processing , suppose a image is captured nd tat image is compared with default image nd then if the captured image is matched by the default image a speech command should be given tis is my idea , i hav completed the capturing the image bt i m getting troubles in comparing that image nd adding speech command to it will you please suggest me
(5,719 Views)
Can i get the documentation for it pease ???
(3,946 Views)
