Machine Vision
computer vision
Hello everyone,
I have a project where i have to detect plastic types using computer vision and a neural network.
Any help how to start ?
(6,001 Views)
Vision Development Module features some classification functions that use the Nearest Neighbor, K Nearest Neighbor, Minimum Mean Distance, and SVM engines.
(5,964 Views)
you could also try the Machine Learning Toolkit for Labview:
https://decibel.ni.com/content/docs/DOC-19328
I have used k-means clustering and it perfoms well.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,955 Views)
thank you klemen...
I have downloaded the toolkit , can you please upload an example ?
Thank you again .
(5,880 Views)
I have used Kmeans clustering for image segmentation:
https://decibel.ni.com/content/blogs/kl3m3n/2014/10/15/color-image-segmentation-based-on-k-means-clu...
There is a seperate .zip of the examples at the link from where you have downloaded the library. You must have missed it. Smiley Happy
K
(5,868 Views)
Hello klemen,
I am sorry if i am asking much but this my first encunter with image processing.
i have seen your code and the clustering it do... so the code is segmentinng the image into the objects?
and if yes my next step would be start to compare the image taken with the learnt images ?
Thank you ,
(5,830 Views)
