Machine Vision
color match
hi guys:
      i want to know ,is there any compare function in vision lib for RGB image , quite simiar as "Golden Template Comparison" for 8bit or binary image.
while "color matching" can only get the score , i need to know where the difference is.
thanks
(3,792 Views)
Can you explain what you mean by difference?
(3,788 Views)
i need to mark and classify all the different  regions
Message Edited by adobefree@gmail.com on 01-24-2010 07:57 PM
(3,755 Views)
Did you try classifying using histogram?
(3,745 Views)
I'm working with color match pattern. If your image acquisition have good quality, you will not have much trouble with it.
(3,726 Views)
