Machine Vision
color image quantization
   please some provide me a code for color quantization.it will be very helpful for me.
as similar to the one in this link http://en.wikipedia.org/wiki/Color_quantization
Thank you
(5,304 Views)
I have prepared a code for color quantization (octree) based on dotNET. I found the library online. The only problem is that at the current state you have to read an image from a file.
I have explained a little bit more here (the code is also attached):
https://decibel.ni.com/content/blogs/kl3m3n/2013/09/06/image-quantization-in-using-dotnet-in-labview...
Best regrads,
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,284 Views)
Hi Klemen,
                 Thank you for the code.while loading the code it is asking for Imagequantization.dll file,where to find that file and also getting errors, i have attached the error image.
Thank you
(5,280 Views)
Wow, sorry!
forgot to attach the dll. I will attach it now! Thanks for noticing.
K
(5,276 Views)
Does it work for you now?
K
(5,264 Views)
Hi klemen,
              you have not attached the dll file.
Thank you
(5,258 Views)
Check the link i posted before!redownload the zip,it should contain the dll now also 🙂
(5,254 Views)
