Machine Vision
color histogram bin reduction
    What method can be used for "color histogram bin reduction",i.e,by using which method we can perform histogram bin reduction for an color image?
if you can provide me with an alogrithm it would be helpful.
Thank you
(4,831 Views)
IMAQ ColorHistograph VI and IMAQ ColorHistogram VI both have "Number of Classes" input. Is that what you needed?
(4,818 Views)
Hi Andrey,
              I am using the same thecnique as in this attached pdf,if you can look into this,you can help me out.
Thank you
(4,811 Views)
   By using IMAQ color histogram and histograph vi, i can able to get the graph for R,G and B in three different graph,
i want to represent R,G,B in a single by combining the the three values of R,G and B of each pixel into a corresponding color.similar to the attached image
Thank You
(4,763 Views)
Hi Madhubalan,
the LabVIEW example finder shows a lot of VIs and projects for different application.
Check the example: Waveform Graph Datatypes
This example shows how you are albe to plot several lines in the same graph.
RupiDo
(4,646 Views)
