Machine Vision
can winddraw make user run-time shortcut menu?
Hi, I am wondering whether winddraw (machine vision, vision utility vi) can make run-time shortcut menu.
Generally, Image window has option(right mouse click) - advanced->run-time shortcut menu which is editable by user.
But when I click the popup window generated by winddraw vi, I can not see any option like image window(indicator)
Please help this issue.
Thanks in advance.
(3,830 Views)
It is my understanding that image windows created with IMAQ Windraw VI do not support run-time short cut menus.  As a workaround, you could create a floating VI that pops up with an image display and has the run-time shortcut menu configured.
(3,791 Views)
