Machine Vision
can not find the imaqReadBarcode2 function in VDM 2015 nivision.lib
Hello
I use the vision assistant to verify read barcode function and generate the c code. but when I compile this code with VS 2012 I get a error that show me "error LNK2019" it cna't find the export function in nivision.lib. I checked the document "NIVisionCSupport.chm" I can find the function information about imaqReadBarcode2 and imaqReadBarcode3. So which lib I need? or how to fix this problem?
thanks
environment : VDM 2015
Lib : nivision.lib
(4,990 Views)
This is a bug an NI will post a patch soon. We will post the link to the patch as soon as it is available.
(4,986 Views)
thanks.
but, where can I get this link? when NI post it.
(4,971 Views)
Hi
Where and when can we get this patch link?
thanks!
ChristopheC 已写:
(4,948 Views)
Hi Coco1020, Will_ZM,
I provided you an unofficial patch last month, but I wanted to notify you (and anyone else following this thread) that the official patch release is now available here: http://www.ni.com/download/ni-vision-common-resources-2015-sp1-f1/5955/en/. I recommend that you install this official patch even though you have already been provided a fix. Thanks!
Joseph
(4,769 Views)
Really thanks, Joseph-S!
Joseph
(4,716 Views)
