Machine Vision
can I use multiple camera
I need to use more than 2 cameras for our production line inspection.
does NI Vision support more than 1 camera input?
if yes, is there any example for this matter?
Best Regards,
(2,054 Views)
I have often used multiple cameras.  GigE, Firewire, and USB
Attached is a 3 Camera capture program, totally inelegant, but should give you a start.
In this case, the camera will free run inside the loop, not just one picture per loop cycle.
Feel free to ask more questions.
(2,017 Views)
Thanks for your help.
I use Vision builder for Automated Inspection software and I need file with vbai extension.
is there any way to change VI file to VBAI one?
Take care
(2,011 Views)
I have very limited experience with Vision Builder, and currently don't have a copy. Sorry, Can't help.
You might need to post the conversion from VI to VBAI as a separate question.
Good Luck!
Robert
(2,009 Views)
(1,988 Views)
