Machine Vision
camera usb3.0 basler error
I have 2 basler aca1440-220um camera when running for 4 5 hours then this error. I reset the program, this error appears continuously, I went into Max to run the same error. I am using win 10, cab usb 3.0Capture.PNGn10, usb3.0 cable
(2,361 Views)
You might want to try tweaking some of the power saving settings as mentioned in this post. Ensure that you are using a recommended USB3 host controller (Intel or Renesas) and a quality USB3 cable (without a hub) that is 5m or less in length for optimal reliability.
(2,246 Views)
