Machine Vision
c code image processing
Dear LabVIEW Experts,
Say I have some C code that takes a pixel array and does some manipulation and spits it back out. I want to capture an image and extract the array via LabVIEW, manipulate the array in C, and then get the new array back into LabVIEW. I understand LabVIEW has VIs for the imagetoarray / arraytoimage, but is there a simple way to integrate the C code? <--- If yes, can you explain it?
I'm using Labview 2011 SP1 and I have the Vision Acquisition software.
(4,433 Views)
Accepted by topic author ledsrcool
I would build a DLL and in LabVUEW use a Call Libarary Node to call that function.
Search ni.com on how to build an call DLLs.
(4,430 Views)
Read help:
IMAQ GetImagePixelPtr Example
Andrey.
(4,426 Views)
