Machine Vision
buy acamera
my application is using match pattern to inspect electronic components on aboard . what are the specifications to buy acamera ?
(3,945 Views)
Hi
Your camera will depend upon the size of the components you wnat to detect on the board. It also depends on distance of the camera from the object.
If you are to detect the electronic components then I suggest you to use an HD camera with high resolution as the components size is going to be very small and try to place the camera as close as possible to the object.
Ninad Regundwar
Ninad Regundwar
Junior Engineer | ARAV Technologies | www.aravtech.com
(3,931 Views)
