Machine Vision
barcode checksum
I'm using a barcode detection on Vision Builder 3.5.
I would check the result with the checksum (code 128).
If I check the option " Add Checksum To Code Read", there is an automatic control of the checksum or only an "adding" of the checksum without control ?????
Thanks.
FM
(3,352 Views)
Hi Fmichel,
it looks like there is no additional control that is created when you use the add checksum option in the barcode detection.
A workaround to access the checksum would be the use of the calculator. You can cut the ID-String so that only the checksum
remains as result.
You can find more information about the barcode and checksum syntax for the different barcode types in the VBAI inspection
configuration help when searching for "Read 1D barcode controls". Hope this helps.
David
(3,332 Views)
