Machine Vision
avi2 not working with queues
Ive just tried both the videos you sent me and it works on both but still my own video file doesn't work. any ideas what the problem could be?
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
Message 11 of 22
(2,096 Views)
yes there is idea why it could not open your avi file
your problem relate about supported codec
fast solution is to convert your file into avi with medium quality and size
install this software http://www.pcfreetime.com/
use convert to avi
and select medium quality and size in output option it is fastest way to get result
Message 12 of 22
(2,094 Views)
I can't afford to lose the quality. Any other way? I don't know what the codec is for my video files. Also I can get it to work using the old version of avi function but then i have the problem of not been able to access these from the palette. Is there a work around for this?
CLAD
Message 13 of 22
(2,063 Views)
try what i told using medium quality it is not means that you will be loose your data that you need it depend on what you need try it maybe it is what you want
also you can add old vi into your pallete
for this one go to tool advance and edit pallete and all your vis to pallete
Message 14 of 22
(2,061 Views)
Changing the palettes didnt work they are all just the same as before. Also I cannot install software to convert right now because I am using a university PC which won't let me install anything. Is there anyhing else I could try?
CLAD
Message 15 of 22
(2,058 Views)
if you could not install any software so you could not install codec too
for last help that i could do for you send your avi file i will convert it for you
hope this  could solve your problem
Message 16 of 22
(2,056 Views)
I think I'll have to find another work around. I could send you the file to convert but this wouldn't be practical as I have around 50 different video files. Thanks you for your help though
CLAD
Message 17 of 22
(2,053 Views)
could you send a example of your avi file?
Message 18 of 22
(2,049 Views)
I can't I'm sorry, I'm not sure if I would be allowed to put it on the internet
CLAD
Message 19 of 22
(2,047 Views)
ok any way this is what i know about avi2
sorry if i cant help you to solve your problem
Message 20 of 22
(2,045 Views)
