I got 2 isa at-5102 to run under dos for speed reason. Im not able to initialise the 2 card. I would like to know if there some driver for NI-DAQ Dos version that can handle these 2 card. I got Ni-DAQ Dos but this model of card is not listed in the menu.
The AT-5102 is an oscilliscope card and works with NI-Scope, not NI-DAQ. If there is a version of NI-Scope for DOS, the engineers who post to the Dynamic Signal Acquisition and Analysis forum under the Measurement Hardware heading would probably know best. If you post your questions there, you should get a quick response.
