Machine Vision
array of pixel coordinates from particle analysis
Is it possible to retreive an array of point clusters containing all points from a located particle using the IMAQ vision toolkit.
I can't seem to find how to do this, and it would be a shame if I would have to write my own particle analysis routine.
regards,
Arend
Message 1 of 10
(4,655 Views)
Try using this vi. Internally IMAQ MaskToROI uses the same code as Particle Analysis.
Kevin C.
Vision Software
Message Edited by KevinC on 10-20-2005 09:32 AM
Message 2 of 10
(4,649 Views)
Ok, I'll give that a try.
Thanks.
Message 3 of 10
(4,633 Views)
I've tried it the way you said, but this does not give me what I want.
Assume a binary image looking like this:
111111111
111111111
111111111
111000111
111000111
111000111
111111111
111111111
111111111
If I use your method, I'll receive the following coordinates:
111111111
1            1
1  11111 1
1  1     1  1
1  1     1  1
1  1     1  1
1  11111 1
1            1
111111111
But not the coordinates of all the pixels containing value 1.
I want to have all the pixel coordinates of all the pixels which are covered by a spot.
Any suggestions?
Thanks in advance.
EDIT: tried to fix layout of 2nd example image
Message Edited by Arend on 10-26-2005 11:12 AM
Message 4 of 10
(4,608 Views)
Sorry, I misunderstood what you wanted. Try the attached VI.
May I ask what you are trying to do? I suspect there may be more tools built in to NI Vision to help you.
Kevin C.
Vision
Message 5 of 10
(4,593 Views)
Thanks for your answer.
I know how to find pixels containing certain values, that's not the problem.
I'm using the software to track bad pixels, columns and regions in a CMOS.
First I check for bad regions. I do this with the find spots algorithm from the vision library.
Now I want to only find spots with a size of at least 100 pixels (for instance) which have a certain contrast etc etc.
After finding these spots, I want to know every single pixel coordinate of the pixels which have been determined to belong to a spot.
If i just threshold my image, I will also find loose pixels instead of just spots of at least 100 pixels.
This way, I would have to check which pixels belong together. But this is already being done by find spots.
So what I'm looking for is to obtain every single pixel determined by find spots to belong to a spot.
Thanks for your help so far, if you have any more suggestions I would be very interested.
Message 6 of 10
(4,584 Views)
I think you want to use Particle Filter and Label. Hopefully the attached example will be helpful.
Kevin
Message 7 of 10
(4,568 Views)
Here's an idea:
Threshold the image.  Use particle filter to remove loose pixels, so that all that remains is the groups that you are interested in.  Use IMAQ Label to label each group with a different number.  Now all you have to do is locate all the pixels with each value.
Bruce
Bruce Ammons
Ammons Engineering
Message 8 of 10
(4,566 Views)
That looks very promising, I'll give that a try.
Thanks for the help.
Message 9 of 10
(4,556 Views)
Thanks for the suggestion, your idea is somewhat similar to KevinC's.
I think with both your help my problem has been solved.
Thanks again.
Message 10 of 10
(4,554 Views)
