Machine Vision
adaptive thresholding
How to do adaptive thresholding on varying textures i.e dynamically fix a threshold value on varying patterns
(3,424 Views)
Hello eskay,
The "IMAQ threshold.vi" has inputs for the range of values you want to threshold between. You can feed new values into this VI each time you call it to change the threshold values.
If this doesn't answer your question please post what software you are using and some more detail on exactly what you are trying to do.
Nicholas C
Applications Engineering
(3,411 Views)
