10-31-2005 07:15 PM
I am new in vision. I have problems in acquiring CMOS sensor image. My project would like to acquire CMOS image sensor digital data by using camera link protocol. I am sure that COMS sensor output is correct and the LVDS transmitter generates signals(I am not sure if the output is correct, it's hard to me to identify them).
The camera file generator always said "Cannot detect valid timing signals. Make sure the camera is turned on, outputing video (not waiting for a trigger). and connect correctly." I had checked my pin assignment between sensor and transmitter IC, and set the Pclk output at 24MHz(The LVDS transmitter IC work at 20MHz~85MHz).
Is there any initial sequence when connecting CMOS camera to a Frame grabber?
Is is possible to acquire the image for a normal CMOS image sensor by using NI frame grabber?
Any advise will be appreciated.
OS:WinXP SP2
Frame grabber: NI-1426
CMOS image sensor: 1.3M pixel CMOS sensor
NI Camea File Generator v2.0
10-31-2005 08:46 PM
11-01-2005 12:32 PM
11-01-2005 08:08 PM
Hi David,
Thank you very much. Your answer helps me to clearfy the timing issue.
I am wondering if it is possible for NI-1426 to grab CMOS sensor image?
Currently the LVDS chip I use is NS DS90CR287, is the LVDS pair of DS90CR288A.
The NI-1426 receiver uses this chip to receive LVDS signals.
My project is to grab the CMOS sensor image by using camera link protocol.
The sensor output image data D0~d7, Pclk, Hsync, Vsync.
I already have the capability to control the sensor register to generate the proper timing and signal phase.
And I follow the siglal bit assignment of camera link protocol to design the PCB(My EV board is 2 layers because of $$$).
Unfortunately, I always get "Cannot detect valid timing signals. Make sure the camera is turned on, outputing video (not waiting for a trigger). and connect correctly." message.
My questions are:
1. Is it possible to grab CMOS sensor image by using NI-1426?
2. Is there any initial sequence when connecting CMOS camera to a Frame grabber?
3. Should I modify camera file by manual to fit my special application?
4. From the error message, it seems I didn't provide the FVAL, LVAL signal. Does the error message mean that?
Thanks in advance.
Neal
11-02-2005 12:27 PM
11-04-2005 04:28 AM
12-22-2005 10:07 AM
