Machine Vision
Would you like to use images larger than 2GB?
Probably most of you do not typically try to allocate images in Vision that are larger than 2GB, but if you have wanted to, or wish you could, there is an idea on the Idea Exchange that would be worth voting for: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Vision-handling-single-image-files-gt-2GB/idi-p/326800...
Note - this is not the same as allocating >2GB of images in total, something that 64-bit Vision can already achieve.  It's allocating this for a single image.
(3,654 Views)
Any specific reason why you posted this idea in the LabVIEW section rather than the vision section of the idea exchange?
The vision team checks the vision section periodically so they might not even see it 😮
Epictetus
Antoine Chalons
(3,641 Views)
It wasn't my idea, I just kudoed it, but yes it could be moved.  The visibility of ideas in the Vision Idea Exchange is pretty low though, so it probably doesn't hurt if it gets seen in the main exchange and then moved across.
(3,607 Views)
