Machine Vision
Why it fails at second picture?
I want make an image panorama by using pattern matching. First I open the 1.jpg then 2.jpg. It is working. But at 3.jpg there is an error: The image is not large enough for the operation. I think there is something storage problem (it is trying to read an empty image). How can I solve it?
(4,846 Views)
Accepted by topic author holex
You have a race condition in your code:  The first iteration of the while loop has the image "1" in the shift register.  At the end of the iteration, you wire the image "resample" to the shift register which will from then on be used.
Later on, "IMAQ Create" will produce an empty image "resample" in the loop.  The error is as expected.
Solution to your code:  Remove the shift register and always use the image "1".
(4,835 Views)
Thank you!
(4,831 Views)
