Machine Vision
Why is image to array (vision call in C++) not then displaying my array in my code?
Hi Kari,
You are trying to display your array by writing to cout, but your application is a GUI app, not a console app, so you don't have a console to write to.  The system call works because it actually invokes a console mode app (most likely cmd.exe) to do its work.  To display from a GUI app, you need to use a UI object.  The easiest (but least flexible) is a message box.
If you want to get something working quickly, consider changing your code to the following:
/* Display the results */
    char title[80];
    sprintf(title, "The array has %d rows and %d columns", rows, cols);
    char startOfData[512];
    startOfData[0] = '\0';
    for (row = 0; row < rows && row < 4; ++row) {
        for (col = 0; col < cols && col < 16; ++col) {
            sprintf(startOfData + strlen(startOfData), "%02X ", (unsigned char)(array[col + cols * row]));
        sprintf(startOfData + strlen(startOfData), "...\n");
    MessageBox(startOfData, title, MB_OK);
-Jeff
Message 11 of 16
(2,685 Views)
Hi Maclean,
I have both run several of the example vis that come with the package and have written my own vision vis, all of which run fine.
Kari
Message 12 of 16
(2,673 Views)
Thanks so much for both of your help. Kellam, this code did work and displayed a portion of my image array.  Is there a way to set this up so it will display on a console?  I think that would be easier and we could see more of the array.  I tried changing the properties<Linker<System<Subsystem from Windows to Console, but then got these errors:
 1>msvcrtd.lib(crtexe.obj) : error LNK2019: unresolved external symbol _main referenced in function ___tmainCRTStartup
1>.\Debug\LoadImArrayCon.exe : fatal error LNK1120: 1 unresolved externals
Also, when I view my image array values in the message box, everywhere I should see a 1, I see an FF. Zero values are correctly output as 00.   When I load in a greyscale image of mine, I also get strange values like B6 AA 92 etc... Do you know why this is?
Thank you so much,
Kari
Message 13 of 16
(2,672 Views)
Hi Kari,
The way I set up the example was to print the hexadecimal value of each pixel - 0 is black and FF is white.  If you want to see values from 0-1, then change the appropriate line to sprintf(startOfData + strlen(startOfData), "%f ", (unsigned char)(array[col + cols * row]) / 255.0);
What you are struggling with is trying to have an application that is both a GUI app and a console app.  When you switched the linker flag, you made a console app; however, you are using MFC for your GUI, which doesn't work unless you link to build a GUI app.
Your two best options are to (1) make a dialog box with a text control on it or (2) allocate and associate a console into your GUI app.  The MFC examples should have some examples on how to make a dialog box with a text control and how to use it.  If you want to allocate a console, I'd suggest reading http://www.halcyon.com/~ast/dload/guicon.htm
Good Luck
-Jeff
Message 14 of 16
(2,657 Views)
Do you know if it is possible to take my GUI app and make it into a DLL so that I can interface with Labview and load my image directly there?  I need to alter my image using Cpp and then load into Labview.  I have tried inserting this program into a newly-created DLL and get many errors.  Is this impossible?  Any suggestions would be greatly appreciated.  Thanks,
Kari
Message 15 of 16
(2,505 Views)
Hello Kari,
We have a Developer Zone tutorial that addresses the topic of Building a DLL with Visual C++.  Please click here for a link.  You may be able to find additional resources by searching www.ni.com/support.
Best Regards,
T. McCarty
Message 16 of 16
(2,486 Views)
