Machine Vision
Why is IMAQdx property node not setting a property correctly?
I'm working with a Prosiclica EC1380 CCD camera. The IMAQdx tools are working great. However, I'm having a problem setting the shutter speed. I'm using the IMAQdx property node to set the gain, but for some reason it doesn't set the shutter speed correctly. Any clues?
-Joel
(3,894 Views)
Hi Joel,
Does the shutter control work properly in MAX? What mode is the shutter in? I tried it here with a Prosilica EC750 and it worked as expected in both Absolute and Relative mode through the property node. In relative the range was between ~0.00002 and 1.0. In relative it is between 1 and 4095. Is the value you are using matching the mode you wish to use?
See the attached diagram showing how I was using it. For simplicity the example is not querying the available range dynamically.
-Eric
Message Edited by BlueCheese on 06-18-2008 02:20 PM
(3,891 Views)
Eric,
I'm not sure why it's working now, but it is. The only thing that is different is that I changed the inputs to the property node from controls to constants, like you have in your example. Now, it works!
Thanks.
Best,
Joel
(3,887 Views)
