Machine Vision
Why does my computer crashes after using my LabView and IMAQ Vision application during several hours?
I'm using IMAQ Vision functions such as showwindtools, showwind, doing pattern matching, color pattern matching, color matching.
(2,877 Views)
I would look for a memory leak of some sort. If you go to your Windows Task Manager, you should be able to see a memory leak slowly taking up all of your system memory. If there is no memory leak, then you should talk to an NI Applications Engineer by going to ni.com/ask. He or she will be able to narrow down the problem and get you a solution.
Kyle V
(2,877 Views)
