Machine Vision
Which is the channel configuration of Max when i want acquire rgb and horizzontal syncronism from pci 1409
I want to know wich is the configuration of 4 channels of Max in "device and interfaces" for pci 1409 for acquire color image from 4 different channel: red, green, blu and horizzontal syncronism. Thank.
(3,527 Views)
An RGB camera delivers the three basic color components (red, green, and blue) on three different wires. This type of camera often uses three independent CCD sensors to acquire the three color signals. RGB cameras are used for very accurate color image acquisitions.
The IMAQ PCI/PXI-1409 board can be used to acquire color images from an RGB camera. For a StillColor RGB snap, connect the three camera channels red, green, and blue to VIDEO1, VIDEO2, and VIDEO3, respectively, on the PCI/PXI-1409 device.
What Is an RGB Camera?
A Talley
Applications Engineering
(3,527 Views)
How it is possible using BNC conector? (The 1410 is able to get full framerate by it.)
(3,166 Views)
