Thank you for contacting National Instruments. With regard to your memory card question, I looked up the serial number that you gave, and that is a 32 MB card. You should be able to see that value when you look at the device properties in Measurement and Automation Explorer (MAX). What version of NI-IMAQ are you using with your PCI card? Depending on what version you are using, MAX may not recognize the memory properly. Try installing the most recent driver from:
NI-IMAQ Version 3.0 for Windows 2000/NT/XP
http://digital.ni.com/softlib.nsf/websearch/C8FAC1A56DD469CA86256EB6007284B5?opendocument&node=132060_US
Regarding the choice of camera, I'd suggest taking a look at our Industrial Camera Advisor, also located on our website, at:
or
http://sine.ni.com/apps/we/nipc.specs?action=search&asid=1102
You can browse that site according to the specifications that you need for the camera to meet or you can click on the link at the top of the document that points you to a list of NI tested and approved cameras.
Let me know if you have any additional questions on this issue.
Scott R.
Applications Engineer,
Scott Romine
Course Development Engineer
