Machine Vision
Vision height measurement of object
Hi, my project consist of a stationary camera placed near the ceiling. The task now is to enable the user to input a height, then the program will only track objects with said height. So far I have managed to create a program that tracks a single moving object using subtraction and centroid blocks in LabVIEW but I'm stuck with the height measurement. Most online sources say it is impossible to do so with just a camera since we do not know the distance between camera and object. Is this true? Or is there a way to do it on LabVIEW? I can upload my VI here if anyone requests.
(4,327 Views)
Hey,
When it comes to using a camera to do measurements which are not just in a 2D plane and you need to do all the math required and cannot rely on the camera to do it for you. I wouldnt say its impossible for you to do this but you defintely need to find a way to do all the math. The math will get harder because you are looking for 3D measurements in a 2D image in pixels. I suggest you to reconsider your hardware configuration and positioning. This is very important and may reduce a lot of math to do. can you share with me what is your current hardware setup like? Any pics and/or diagrams are appreciated.
Thanks.
(4,302 Views)
there are some method to do this but the resolution of your distance measurement is issue that you have to concern about it
(4,280 Views)
