Machine Vision
Vision deployment license for PCI 8252
Do I need to buy a seperate runtime license for deploying vision on a different pc using NI PCI 8252
(4,386 Views)
With your order of a PCI-8252 you also get a Vision Acquisition license for it. So there is no need to order it separately.
If you deploy a vision application (created e.g. in LabVIEW or CVI) that bases on functions available in the Vision Development Module you will need a license of the
Part Number 778044-03 NI Vision Run-Time License.
Hope this helps, Guenter
(4,380 Views)
Im not sure but you might have one vision acquisition license included with the vision development module license. Does anyone know for sure?
Certified LabVIEW Architect
(4,298 Views)
Yes.  You do have 1 license for the Vision Acquisition that is included with the Vision Dev Module. The serial number you should use for Vision Acquisition is the same serial number you used for the Vision Development Module.
Evan D.
Installer R&D
(4,274 Views)
Thanks for confirming that.
Does it also include one runtime license for the Vision development module itself?
TIA
-Martin
(4,254 Views)
Yes.  The Vision Development Module includes 1 Runtime license.
Evan Dozier
Evan D.
Installer R&D
(4,235 Views)
Thanks for clarification, Evan. I didn't know that and never read it in the product description.
Have a great day, Guenter
Message Edited by Guenter Mueller on 10-10-2007 09:11 PM
(4,212 Views)
