Machine Vision
Vision assistant vi autonatically integrate
I´d like to automatically integrate generated VIs from the Vision Assistant in an existing Labview VI. Can somebody help me?
Some more explications about my problem:
My Labview Programm recognise if a light is lighting or not. Every time I change the kind of light that has to be controlled, I have to create a new template and a new Vi from Vision Assistant has to be integrated with copy and paste in my Labview Programm. May I automate this process?
Thanks for any answer
Dijo,
(3,017 Views)
The VI generated by Vision Assistant reads a template from an image file. It doesn't seem that you would need to create a VI each time. It should just work if you replaced the template file that the Vision Assistant generated VI reads. When the light turns on, you should relearn the template and save it to the right location. Vision ships with some example that show how to learn a pattern matching template.
Christophe.
(3,005 Views)
