Machine Vision
Vision.WindowsForms.ImageViewer.ZoomToFit works only until manually zoomed
I am displaying a live camera image in a Vision.WindowsForms.ImageViewer (in C#). Whenever the user changes the camera resolution (Binning / Roi) I want the image to be scaled to the full Viewer size. This works well by setting ImageViewer.ZoomToFit to true. But once the user has zoomed in/out manually the zoom factor remains fixed. This results in the image not filling the viewer any more when it's resolution is changed. Can I reset the Viewer to zoom to fit again after the image resolution has changed? A manual call would be fine. Setting ZoomToFit again doesn't work. Thanks in advance for youre help
(3,364 Views)
Hi Neutronensturm
When resizing an ImageViewer in a C application with the ZoomToFit property set to true, the image size remains constant instead of filling the ImageViewer area.
This is a known issue with .NET and the ImageViewer, and has been filed as CAR 188008
For a workaround please have a look at this post:
ImageViewer canvas does not resize when the ImageViewer control is resized .NET
Hope that helps ?
Kind regards
Pixar
(3,343 Views)
